E-brake light coming on continuously as well as e-brake not working well?
DLo
57
I've found a ton of information on this site through searching, and a great deal of it has been really helpful to me. But I can't seem to find a single thread on e-brake issues, and it seems to be a common problem. Lately my light comes on randomly when I drive, and the ebrake is released. Usually happens when I downshift I think, and am slowing down. Also, the emergency brake doesn't seem to grab at all. I have to leave my car in gear if it's parked on a slope, otherwise it will just slide. Any ideas?
The light on the dash does two things. It indicates when your parking brake is set. There is a switch on the handle. when it's up, it's on.
The other thing it does is let you know when you are low on fluid. If it is coming on when you are slowing down, it means the fulid is sloshing to the front of the Master cylinder, and causing the light to come on. IF you ignore it for a little while longer, it will be on all the time as the fluid will be low enough. Rather than just top it off, though, You probably need to look at your brakes. All the fluid that WAS in your master cylinder is now in your calipers because the brake pads are worn down. Time for new ones. The fluid will "magically" re-appear when you push the pistons back into the calipers....
Oh, and your Parking brake needs adjusting.
You also may have air in the lines. If you have opened any of the lines, like if you swapped calipers, you need to bleed the brakes.......
Or if the fluid is low, that will do it as well.
Scott
Scott
Oh yeah. Air in the lines will allow the pedal to go too far down, which will ALSO turn on the light....
