E-Brake Loose?
There are 2 bolts that hold it to the floor, and once you lift up on the H/B the Spring Pressure will release and then you can crawl underneath and pull the 2 cables off the Equalizer Bracket. On your new H/B wind the Spring and put a nail through the Hole in the Handbrake and that will hold the Tension on the Spring which will allow you to hook the 2 cables back up to the Equalizer Bracket, put the 2 bolts back and remove the nail and you are good to go.
Hey shaker,
I got one of ebay for cheap, i dont understand when you say crawl underneath, crawl underneath what, the car??, i also dont know what the equalizer bracket looks like (pic would be awesome).
thanks again in advance,
-Nick
Yep, underneath the Car. The EQ Bracket is connected to the center cable from the Handbrake and the left and right cables on the underside of the car attach to it.
So are you saying that the EQ bracket will fall off when i disconnect the center cable from the handbrake?
In the post you had about telling me how to do it, you said nothing about the center cable?
