E-brake????
  • Thread starter Thread starter Beasty306GT
  • Start date Start date Nov 21, 2008
Beasty306GT
671
Oxford,Mass
Nov 21, 2008
  • Nov 21, 2008
OK i have to remove my rearend for painting the chassis and rearend. WHat is the easiest way to disconnect the ebrake lines going into the drum housing? I would assume i have to take the drums off and take the shoes off??? Any help or tips would be helpful and also whats the best way to disconnect the brake line at the top of the housing at the block?? Withiut loosing a lot of fluid..i know i will have to bleed them anyways
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 21, 2008
  • Nov 21, 2008
Go to hardware store and buy a 3/8- 24 bolt as short as possibly. Get a copper washer and a few normal washers to take up space.
Unbolt the brake line from the hard line on the body, then thread the 3/8" bolt into it's place and snug up. That will prevent fluid from leaking out of the body lines
Beasty306GT
671
Oxford,Mass
Nov 21, 2008
  • Nov 21, 2008
OK thanxs man..thats the 1 bolt with the flex line on the body right? And do u know how to disconnect the ebrake cables?
Beasty306GT
671
Oxford,Mass
Nov 22, 2008
  • Nov 22, 2008
Anyone?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 22, 2008
  • Nov 22, 2008
Not drum brake cables sorry. When i took my drums off, i just cut them with snips. I have disks now.
old_blue
1,783
282
124
Nov 22, 2008
  • Nov 22, 2008
iirc, you have to pull the drum to access the point where the cable attaches to the brake pad. the end of the cable has a knob on it that connects to a c-clip type bracket. kinda of a paint to get in and out of the bracket. good luck.
Beasty306GT
671
Oxford,Mass
Nov 22, 2008
  • Nov 22, 2008
thats what i figured...ill screw with it tomorow or next week sometime...thanxs for the help
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
