E-Cam work for turbo use?
MustangGroupie
23
I have some mods including the e-cam. Purchased a holset e-1? (64 trim compressor side, has a 127 A/R) Was wondering if there would be any overlap problems using that cam and turbo setup. Any comments appreciated.
5.0 HOtrain said:
Christ, the stock cam works sweet with a turbo too. Good luck and hang on once the install is done.
mike.
Performer rpm intake I mean, Yeah i heard the stock cam is good do to lack of overlap, But i dont feel like taking the bitch apart again until i do heads.
MustangGroupie said:
Is the Performer rpm to much for a mild turbo setup?
Are we talking the RPM Heads or Intake ?
Eigther way it'll be fine (intake or heads), just think of it this way... the more efficent it is NA the better the turbo motor will be. A little overlap won't hurt especially with lower boost levels, but once you start talking high boost then you need to be mindful of it(overlap)
