E303 + 1.7 rockers = ?
  • Thread starter Thread starter myles
  • Start date Start date May 16, 2009
M
myles
15
Illinois
May 16, 2009
  • May 16, 2009
I know I have read this discussion here before but I wanted to recap for myself some of the info from you giuys. I have an 98 Explorer 302 going in my mustang. I have an E303 camshaft in it now, and I already have put the trick flow spring on the heads as recommended by all. I got some crane 1.7 roller rockers from a friend really cheap and wanted to know if there is any problems with me using those rockers? Can I use the factory size pushrods or do I need to change that also? I am trying to keep it simple and not confuse myself. It will have full length headers and 2 1/2" exhaust if it matter to anyone, with 3.73 gears and man trans.
Thanks
Myles
P
phutch11
328
May 17, 2009
  • May 17, 2009
Factory pushrods will be fine assuming you haven't milled the heads, block, or put new pistons in. If you have check the PV clearance.
Good luck...
Posted via Mobile Device
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 17, 2009
  • May 17, 2009
I could be wrong but i've always heard that rocker ratio only effects max lift, not duration (someone please correct me if i'm wrong). So assuming that's true you're only at about .530 lift with 1.7 rockers. There's a misconception that lift is the problem with PTV clearance where actually max lift occurs when the piston is on the intake stroke moving down the cylinder AWAY from the valve...it's duration and advance/retard that cause PTV problems (as well as valve size and piston relief size obviously). You could theoretically have a cam with .999 lift and run it on a stock piston engine as long as the duration was short enough that the valve was closed again before the piston make it back up to the head.
MAC'n89Blckstng
1,012
NJ
May 17, 2009
  • May 17, 2009
I have them on my motor, no clearence problems. Although its too much lift for my unported GT40 heads. The only flow to .500 lift.
87&89stang
  • May 17, 2009
whats up everyone im freddy and im new at this... i have edelbrcok heads and a f303 cam with 1.7 rockers and 347 stroker assembly... as mention on top will my valve hit the piston
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
