e303 cam?
  • Thread starter Thread starter deftsound
  • Start date Start date Oct 17, 2004
1 of 2 Next Last
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Oct 17, 2004
  • Oct 17, 2004
hey guys,
im building a list of things im going to put in my engine when i rebuild it this winter and im having a dillema over which cam to choose. I want a cam that give me good power for the money, has a good lope sound but isnt too radical of a cam. Lately ive been reading and from what ive gathered the e303 cam just doesnt produce very noticable gains. Am i wrong?
So far im thinkin of this:
Edelbrock Performer RPM intake manifolds
Edelbrock 70mm TB
E303 cam????
Rebuilding my stock heads and having them mildly ported
Ford Roller rockers
tell me what you think...
TrickStang37
292
  • Oct 17, 2004
i noticed a difference with the cam. as for porting the stock heads, i wouldnt pay for it. if you were doin it yourself, then yeah. The $$ you spend on the port work could just go towards a different mod that will probably net you close to the same gains and then can also use when you decide to ditch the stock POS heads.
C
Chris6050
188
Nazareth, PA
Oct 17, 2004
  • Oct 17, 2004
I agree with TrickStang37.
As far as the cam goes, I think the E303 is pretty good cam. Slightly outdated yes, but still works. I would recomend A Trick Flow stage 1 cam over it though. It's cheaper, makes more power, and sounds better. Some people say it lacks on the bottom end, but I installed mine 4* advanced and it rips.
BillaMustang
491
  • Oct 18, 2004
the "E" cam is an old design, but works great.
i had one in my 302 and it ran pretty good 12.00@116mph aint bad.
are you buying new or getting a good deal ?
deftsound
Apr 6, 2004
945
Texas City TX
Oct 18, 2004
  • Oct 18, 2004
depends, ill probably buy it used off ebay, i was thinking of comp cams XE258 or XE264, someone on here said they were good choices.
deftsound
Apr 6, 2004
945
Texas City TX
Oct 18, 2004
  • Oct 18, 2004
how much do you think having my heads rebuilt and ported would cost?
Also, what else would i need to replace while im doing my camshaft, i know i need roller rockers but what kind, what else would i need to replace?
bln92cpe
158
Los Angeles, CA
Oct 18, 2004
  • Oct 18, 2004
I love my E cam, it thumps on my 306 and is perfect..I might go with something more radical if I drop in a 408, but for now i am happy.
Gixxer750
789
Saint John NB, Canada
Oct 18, 2004
  • Oct 18, 2004
Will an e-cam go into a mostly stock MAF car and work ok?? Do u need to buy stiffer spings??
T
tjm73
2,418
Rush, NY
Oct 18, 2004
  • Oct 18, 2004
Edelbrock 70mm TB
E303 cam????
Ford Roller rockers
WAY TOO much intake for the heads you'll have. Do you plan to upgrade to better heads in the near future (next year or so)?
TrickStang37
292
#10
  • Oct 18, 2004
  • #10
basically i wouldnt mess with the intake/cam on a stock headed vehicle, they're matched up pretty well as is. You would have much more fun with gears and could benefit later when you really decide to upgrade. a ballpark figure for the heads would be like $200 each to get them rebuilt + port work, which around here is like $500++.
TrickStang37
292
#11
  • Oct 18, 2004
  • #11
and you will probably want to uprgade the springs as well if you want to run the e303 unless they have low miles on them.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 18, 2004
#12
  • Oct 18, 2004
  • #12
Nope...stock intake sucks. Lower anyway. At the very least I would consider having it ported. Good call on the gears though. Performer RPM is a little too much intake for what you've got. You'de be just as well buying a standard Performer if you're going to replace the intake.
As for cam selection....Either one of those CompCam grinds will perform better at ALL RPM than the E303. The only advantage that the alphabet cams have over most dual pattern grinds on the market now a days is that they're cheap. You'll want to upgrade your valve springs if you've got any sort of mileage on them. I'd change them out just the same. The stock ones are barely up to the task of spinning the stock bump stick, never mind one with a little lift and duration.
deftsound
Apr 6, 2004
945
Texas City TX
Oct 18, 2004
#13
  • Oct 18, 2004
  • #13
ok so heres the list:
1) E303 Cam
2) Edelbrock Performer Intake manifolds
3) 70mm TB
4) Rebuilt stock heads (ported if i can afford it)
5) Double Rolling timing chain
6) New valve springs
7) Roller Rockers
8) All new gaskets
do i need new pushrods or anything to handle the new cam or will this do it?
maverick0716
3,924
Chilliwack, BC, Canada
Oct 18, 2004
#14
  • Oct 18, 2004
  • #14
Did you look up the power band for the E303? It goes to 6000 rpm.....thats WAY too much for what you need. My opinion is go with one of the Comp Cams mentioned earlier.
deftsound
Apr 6, 2004
945
Texas City TX
Oct 19, 2004
#15
  • Oct 19, 2004
  • #15
well what do you guys think of the trick flow stage one cam?
PhLoBuS
473
Beverly, MA
Oct 19, 2004
#16
  • Oct 19, 2004
  • #16
e-303 goes to 5500...
lager94GT
119
LI, NY
Oct 19, 2004
#17
  • Oct 19, 2004
  • #17
I like the E cam. I know there are newer and possibly better cams that can be matched to improved combos. I have the e cam with ported gt40 heads and cobra intake (lower ported on my bench) and I made 276 rwhp/314 torque on the dyno last month. At the time, I had an 11.5 air/fuel ratio. I've since leaned it out a bit.
I feel that the E cam has good driveability for a street car. Also, the restrained lope is nice.
M
Matts89LX5.0
1,314
Long Island, NY
Oct 19, 2004
#18
  • Oct 19, 2004
  • #18
I like my E cam in my motor. I have P/P E7 heads, and the usual bolt ons. Car lumps pretty nicely. Car doesn't make power over 5500 rpms. It is pretty much a combination of the stock heads and the cam doesn't make power over that area RPMs. Overall its a good cam and I wouldn't hesitate to go with it again with STOCK heads.
TrickStang37
292
#19
  • Oct 19, 2004
  • #19
i was getting my best MPH's shifting at 6000 with the e303 with the street heat intake, 65mm tb and 73mm MAF.
84blkstang
544
Springfield MO
Oct 19, 2004
#20
  • Oct 19, 2004
  • #20
What i would recommend is call CompCams and tell them what you have done to your car, and where you want to go with it. They can recommend a cam for you. I did and couldnt be happier, I got the comp 270XE and it sounds good and pulls like hell from idle to 5800-6000. Just a thought
1 of 2 Next Last
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
