Given the following setup, which of the two Ford cams will produce more low-end torque, E303 or B303? And what about idle quality?
Intake side:
AFR 165's
Trickflow idle to 5500 rpm street intake
Ford 70mm throttle body
Pro-M 75mm MAF
Exhaust side:
BBK long tubes
Off road H-pipe
Magnaflow cat/back
Thanks in advance!
Matt
Intake side:
AFR 165's
Pro-M 75mm MAF
Exhaust side:
BBK long tubes
Off road H-pipe
Magnaflow cat/back
Thanks in advance!
Matt
I just read something about this topic a couple weeks or so ago. Seems that what I read said that above 4000 rpm that there was little to no difference between unequal shorties, equal shorties and longtubes, but that below 4000 long tubes had higher torque numbers. Can't remember where I read this though, give me a little time to find it. And if I can't then I'll concede the point.
