do I need to do anything to swap a set of late model e7 heads onto an early 302? the block is date stamped as a 74.
other the the front one) As for pushrods, you'll need ones for a 78-84 302 ( pedestal rockers and flat tappet cam) I'd also do a clean up on them with a die grinder before using them, grind the thermactor bumps down flush in the exhaust ports and remove any other sharp edges in the chambers and ports. If you're gonna have them reworked, I'd also blend the bowls too, under the valves.
