Expired E85 5.0l For Sale
twotone93
pa
5.0l (302) out of a 1993 mustang set up to run on E85
stock bottom end
trick flow twisted wedge heads, valve job done last winter and shaved .020" with 59cc combustion chambers, bowl work done and matched to fel-pro 1262 intake gaskets, new valve springs, ford motorsport 1.6 roller rockers
trick flow push rods
trick flow roller lifters- new
new front and rear main seals, timing chain cover, head gaskets, and intake gaskets
double roller timing chain
anderson ford n-4 cam .554" lift, 280/288 duration 110 lobe center
canton 7qt oil pan
70mm accufab t-body, 80mm pro-m mass air meter, anderson ford power pipe
anderson ford PMS programmer and 38lb/hr injectors for running on E85
edelbrock performer rpm efi intake matched to fel-pro 1262 gaskets
top gun 150 hp nitrous plate system with jets to run on E85, full bottle lines and brackets
1 3/4" mac long tube headers with 3" collectors
msd distributer, coil, and 6btm ignition box
paxton fuel pressure regulator, auto meter fuel pressure gauge, auto meter nitrous pressure gauge
anderson ford big pump inline fuel pump
nearly $8000 total investment i have some pics if your interested
engine is still installed in vehicle and in running order
$4500.00 obo
