E85 switch
bad98gt
running vortech supercharger with after cooler. Im thinking about goinging
to E85
Have 42 lbs inj. and two 255 fuel pumps.
what has to be changed and what else do i need?
Basically, you need a way to tune the timing and fuel curves, and a sufficient fuel supply.
On the fuel supply side, you'll probably want more than just a 42lb injector. It sounds small to me, though I didn't do the calculations. I would guess 2 255hp pumps will be sufficient. On the 88, I'm running a single 255 in tank and it has been good for just over 300rwhp. I expect the single pump to be too small for 400hp though.
I would sugguest a smaller pulley to take advantage of the octane. :D It is seriously awsome fuel. I was running 25psi from a tiny inefficient turbo, on 8:1 compression, in the summer, with an intercooler that is too small, and threw a 35 shot on top with no detonation. This year, I'm increasing the compression to 10:1, planning to run 20-22psi of boost with a small shot on top for good measure. E85 has excellent charge cooling and detonation resistance. Make use of it! :nice:
BTW, you don't need to change any O-rings or seals.
