easy question (I think)
  • Thread starter Thread starter Orange...
  • Start date Start date Jan 2, 2007
Orange...
59
SASKATOON
Jan 2, 2007
  • Jan 2, 2007
so... quick and easy question...
Mach460... aftermarket Kenwood deck... sub and amp addition, can you use the rca's on the back of the deck or is there still the problem and you have to tap into the rca's?
I only read this forum so I thought if I posted in the sound and shine I'd forget anyways, and never know the answer.
BTW 1996 'stang stock everything except deck.
Thanks in advance... and mods, move it if you must... but I'll forget...
Orange...
59
SASKATOON
Jan 3, 2007
  • Jan 3, 2007
well either no one knows the answer or... my question made alot of people really angry and are purposely not answering the question out of spite...
Someone must know, just give me a simple yes or no answer, takes two seconds... can you use the rca outs?
Thanks..
04DarkShadowGT
474
Fort Wayne, IN
Jan 4, 2007
  • Jan 4, 2007
I dont see why you cant use the RCAs on the kenwood deck to power an aftermarket amp.
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Jan 4, 2007
  • Jan 4, 2007
If the deck has RCA preouts and the amp has RCA in's you can power it. That's what they were made for.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Jan 4, 2007
  • Jan 4, 2007
Are you using that harness adapter for the Mach 460 that uses the RCA preouts on the aftermarket deck? If so, then you can get a pair of RCA y-splitters to hook up another rca cable to an aftermarket amp, if you don't have more than 1 set of preouts on the Kenwood. Most newer decks come with multiple preouts these days, some even including a mono subwoofer output.
Dusstbuster
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Jan 4, 2007
  • Jan 4, 2007
^^Never thought of that...this is true. If you are still using the stock 460 amps for whatever reason and used the harness that plugs into the preouts on the headunit thus filling all the preouts then yes you will need to buy a splitter. I don't know why you'd want to use the stock amp's though, they sound like crap.
mineralgray2002
33
Centralia, Illinois
Jan 4, 2007
  • Jan 4, 2007
i took my car to an audio place when i wanted to add an amp and subs to the trunk with an alpine headunit, they had to add what looked like an equalizer behind my headunit for my mach 460 to work, i think they did it to get money. But if you have some rca's just get splitters or they even make a box now that you can wire into the signals going to the factory amp and hook rca's into it, walmart actually sells those.
Orange...
59
SASKATOON
Jan 4, 2007
  • Jan 4, 2007
that answered my question. Thanks everyone. I do have the stock 460 amps and speakers... I also have the scosche (sp) converter run through the rca's I believe (to run the factory amps and speakers with an aftermarket deck) ... So I guess I need the rca splitter.
On second glance... I used this...
http://www.crutchfield.com/S-U9KC1O...tab=morephotos&pi=1&i=142C4FDK5&display=L#Tab
So I think I can just run it to the rca's...
Once again... Thanks
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
M
After Market Gauge Cluster 2001 Gt
  • monkeylikestodance
  • Oct 20, 2024
1996 - 2004 SN95 Mustang -General/Talk- Oct 21, 2024
Mustang5L5
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
L
2003 New Edge Mach 460 question.
  • LightSkinMocha
  • Jul 6, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Jul 27, 2023
Ranger
