  • 1994 - 1995 Specific Tech
Easy question, Welding torque boxes?
  • Thread starter Thread starter 1slow95
  • Start date Start date Feb 25, 2007
1slow95
1,797
ohio
Feb 25, 2007
  • Feb 25, 2007
Is it ok to weld the torque boxes up with the LCA's still attached? I figured I would do this when I install my SFC's I'll be ordering sometime soon. I have access to a drive on lift, but if I need to remove the LCA's I'll have to leave the car on the ground.
Also, will this be enough or should I get one of those kits that strengthen the torque boxes? I don't think my suspension set up will allow me to do any wheels up launches, but I'd like to try it once or twice.
Bosko5.0
1,067
longwood, FL
Feb 25, 2007
  • Feb 25, 2007
remove them or you cook the bushings
1slow95
1,797
ohio
Feb 25, 2007
  • Feb 25, 2007
That sucks, but that's kind of what I was expecting.
SQUEEZE&STROKE
SOUTHERN CA
Feb 25, 2007
  • Feb 25, 2007
Make sure to take out the rear set AND THE INSULATION...I learned that the hard way...burning interiors are not fun!
1slow95
1,797
ohio
Feb 26, 2007
  • Feb 26, 2007
For some reason I can't figure out how to remove the rear seats.
Any help?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 26, 2007
  • Feb 26, 2007
seat removal
SAWZALL or SKILLSAW na im just kidding there are some annoying little bolts on the back of your seat you have to get to them through the trunk and you have to pull that insulation off. at least that how my girlfriends old 3.8 P.O.S was. we had her seats recovered and i helped the guy take them out.
reddy351
560
12
38
Columbus, Ohio
Feb 26, 2007
  • Feb 26, 2007
From what I understand, the torque boxes are kinda weak to begin with. I'd say that if you are going to be under there with a welder, you might as well add the reinforcement kits to them. I think the kit is kinda cheap, like less than $50. It all helps.
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
A
Fox Foxbody convertible pinch weld question
  • Augy
  • Sep 23, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2024
Augy
A
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
