Eaton TVS style supercharger for small block Ford
nicholase
I lubed and pushed, until it was all the way in
May 21, 2024
632
1,124
103
New York
Huh, just stumbled across this. Looks interesting. A modern Eaton intercooled TVS style positive displacement supercharger kit for small block Ford. It's even 50 state legal.
After reading the tech download from their website, it's not the typical plug and play set up most of us think of when we hear "kit". Swapping to a coil on plug / crank trigger setup is needed, and accessory drive mods. So cost it's likely going to price most out. But I like it none the less!
I was reading the company bio. It looks like Harrop is an Australian company that provided Ford Australia and Loutus with custom manifolds to adapt superchargers for production vehicles. So I'm guessing they know what they're doing.
https://www.harrop-usa.com/tvs2650-small-block-ford/p160
Not included in that kit is the Engine Management system for the CNP, the cam sync, the Ignition system for CNP, the plumbing/tank/pump for the I/C and quite a few other misc items.
Figure $17-20K to pull it off.
Not counting labor, assuming you don't install yourself.
Yes, but 1,250+ HP is worth the PITA. Lol
I was on the other end of the spectrum. I wanted (and still want) on-demand, big-block performance without a fuss meaning: No special fuels, juices, etc...
I would [love] to take the intake above and adapt it to a 2.8L KB. :rlaugh:
The down-side... The torque on the street. LAWL
How hard is it to mini-tub with an MM 3-Link? :chin
I fit a 275/60/15 M/T Drag Radial in the stock wheel wells of my 89' Saleen.
Roll the fender lip, some light massaging of the inner fender in 2 spots with a 5lb hammer.
Getting the right offset wheel is really important, (I have 10" wide double beadlock rims) and the quad shocks must be deleted.
Otherwise, I don't see a problem with a mini tub and a MM torque arm set up.
Even with all of that, on the street? Boost control, timing control, traction control of some kind would be needed. Especially on the hit from a dig.
A 2.8 KB can easily get 20 psi. or more depending on displacement and combo.
MM torque arm and panhard bar with SN95 axles under my Coupe and have 275/40R17 Nitto drag radials under it with zero issues. It does have coil overs in the stock shock locations and no quad shocks. I would really like to minitub the car but cutting the panhard bar down would be some work.
Reactions: nicholase
