ebay twinturbo kit?
turbogirl00
i made the mistake and bought that twinturbo kit from ebay and i doesnt come with downpipes. the turbos mount off the maifolds and i need to find a place to get the downpipes for the kit. the company ssautochrome doesnt have the pipes. any ideas where to get them. also where can i find a oil pan predrilled for turbo oil lines. thanks for any help
chances are, you'll have to get them made. where do you live? maybe someone on here knows a respectable turbo-oriented shop that can help you.
as for the oil pan: again, you'll probably have to do that yourself.
You just tap the pan like a Vortech A trim and the directions are on the Vortech site you just do it for both sides. The down pipe is easy enough since the V-Band is for a 2 1/2 pipe that goes back then 45* down to the H-Pipe. Have you fitted the drivers side up yet because the turbo does not clear the brakes and you will need to change to a left line unit or go manual brakes.
the kit was on ebay under turbomustang its on a blue carpet. it doesnt seem like the turbos can mount off the manifolds. wont anything be in the way? im going to run nonintercooler at 10psi i just need the downpipes made
