ECM 41 and 91 again
shotsy242
12
Hey Guys,
I've got the dreaded ecm 41 and 91 codes on my 92 Fox with KOER and i've thrown the book at it.
Fuel pressure is 39/40 with the vacuum disconnected from the regulator.
--Changed the regulator and fuel pump anyway
--New Ignition/complete tuneup, plugs, wires, cap, rotor, coil etc.
-- New 02 sensors on both sides
-- Egr Delete with the resistor triangle installed
-- smog pump delete (Thermactor tube just bent over)
-- All vacuum lines capped off except for brake booster and fuel pressure regulator
The only thing I can think is that I'm sucking air through the thermactor tube thats bent in half on the passenger side, I've got the plugs to go into the heads but it's going to be a PITA getting them in back there.
Anyone have any other ideas, tips or advice?
Mod's I meant to post this to Fox 5.0 Tech can you move it?
I think it is the result of you tricking the computer by installing the resistor...
Normally, if the EGR is not present, you get the CEL and the computer disables the EGR function...
But, when you put the resistors in there, the computer doesn't think anything is wrong, so it acts exactly as it would if the EGR was there...
And what it does when the EGR is functioning is pull fuel under light load...so, your computer is pulling fuel to compensate for what it thinks is a properly working EGR, when in fact there is no reason for it to pull fuel...so you are lean at part throttle...
My two cents...
If I remove the resistor triangle will the CEL light stay on?
Also yeah I'm getting horrible mileage as the computer is dumping loads of fuel because it thinks it's lean.
Please post in here if you do get it figured out because I am at a loss on my car also. But I did see another thread about the salt and pepper connectors causing a similar issue also, mainly a high idle and a ghost cel.
The egr plays a role in fuel economy as well.
Remove the resistors and let the computer see the egr is failed and eliminate that function. Reset all the codes, drive and see if you get the 41/91 again.
If possibly, restore the egr to working condition. There is 0hp to gain by deleting it, and having it working actually improves fuel economy. It's not bad to have.
Also, if your thermactor tube is open to atmosphere...well thats not good either. It needs to be blocked off.
I did the TRANSGO AOD-HP reprogamiing kit this past weekend ahd had to remove the O2 sensors to do it because with the LT headers theyr'e blocking the trans pan from comming down.
Anyways while I had them out I cleaned op the connectors really well and tightened the female connectors on the O2 harnes with a scribe.
After my check ride for the shift kit, I pulled the codes and the 91 is gone but the 41 still persists. I had to extend the 02 sensor leads because of the headers, so I guess now I'm going to pull the passenger o2 out again and see if I can tweak the connectors a bit more. It's been so dang cold here that I'ts hard to get out and roll around under the car.
I've also been reading the internets and it seems that long tubes can cause probs sometimes because the exhaust cools down too much (perhaps BS)
