Engine ECU Question
I'm the original owner of an 89 5.0 LX, 5 speed. It has low milage, but as I'd like to keep it for a while, thought it would be a good idea to accumulate some spare parts while they're still available. One of these spares would be an ECU. The original part number is E9ZF-12A650-A2A. Some vendors have these, but they're over $700. I've found another less expensive one with a part number of E9ZF-12A650-AA. Would anyone know if these are interchangeable? Thanks for any help.
I'd definitely have my original rebuilt as you suggest if it fails. I was hoping to find a reasonably priced backup though as I've never had a lot of long term luck with these things. At least on Chevy's. Thanks for the responses.
I can't really speak to how Chevy and Ford ECUs are different in their construction but if you poke around on this forum and other late model Ford forums you will find that Ford EEC-IV computers are very solid. Issues are uncommon and when they do pop up its almost always aging capacitors, which by this point is a well documented and repairable problem.
Buy a spare off local facebook, don't pay eBay prices, three letter catch codes really don't matter to much vs matching auto to auto and 5spd to 5spd.. Rebuild it or send it out. Only one I would send one to is keyworks, too many others replace a few things and gives everyone the same canned response of we replaced so and so.
Most I'd pay for a core is $120 and at this point in age there all cores, never had a problem finding one. There dead simple single layer boards.
As you can see, I like red. I think I'll get the cheap AA and skip the A2A and hope for the best.
If all's good now, although I'd send it to get checked anyway, cheap tuneup so to speak, it likely won't tell you it's malfunctioning, you have to ask the computer, I'd look for a A9L on the facepage local, you can hold it in your hand.
700 bucks and ebay? Not me.
Reactions: Mindseye007
They do seem to bring a surprising amount of money. Probably the only car I ever bought that I could get what I paid for it. On the AA suffix ECU, it looks like they're listed at various parts stores, but are no longer available. Guess when mine goes bad, I'll send it off for rebuild or replace the capacitors myself. The Ebay prices are pretty steep, even for the used ones. Thanks again for all the comments.
I think the demand for those ECUs is high not because people need to replace ones that are broken but because a lot of people are V8 swapping factory 2.3L cars. Turns out its pretty easy to do and its a lot easier to find an unmolested 2.3L compared to a factory 5.0L if you're on a budget.
  • PlusOne
Reactions: General karthief
Just me but I’d rather send the ECU off to get refurbished now than it fail on a drive and require a tow.
They replace a lot more than the caps.
@GeorgeE For just your own labor involved, you can disconnect you battery, remove the ecm and check the condition of the capacitors and see if any are bulging on the top. While you are doing that, write down the numbers off of the caps and then order some of those to keep on hand.
I haven't ever replaced any capacitors in these ecms but I have in a flatscreen TV. The biggest thing is using some kind of paste or liquid flux to make the soldering process go smoothly.
Just send it out.
Most likely they will reflow all the weak spots and change the caps at a minimum.
I also don't disagree with a spare.
Keep and eye out and when you find one cheap, buy it and send that one out.
Since you don't need it right this second, you can price shop.
it's because cardone no longer exists, decades of people turing in none matching cores, frying the ground trace from mixed match wiring and never fixing them and now ppl hoarding them. then monkey see monkey do using eBay as a price guide. just like everything else it became an over hyped over priced item.. cores dried up years ago and cardone is officially done with the first brands bankruptcy, so better buy what ever oem reman. parts you want now that can still be found while you still can.
I never paid more than $120 for mass air ecu, bought new old stock remans off eBay for as little as $50 because they get listed by brand part numbers only some times. At the prices there asking now I 'd buy and wire up a maxxecu. Hell even a pimpx, termintor x or mega squirt over the massively out dated eec iv and I have spares for every car I own still running one. There insanely cheap to fix if you can do a board level repair , there not at all a rare item, just hoarded and bought by flippers when the price is reasonable. Hardest part is sourcing some components if its not a normal failure, but plenty of other ford ecu's that are pretty much worthless that can be used for donors on some hard to find components.
Reactions: Potomus Pete
