Hello,
I have an 85 coupe that has the is still using the factory dash harness but the engine harness is from a 93 efi car. Got the car running, everything is fine, however I am troubled on a small part of the wiring. The brown connector located behind the drivers side shock tower has a gray/red signal return wire that is suppose to connect to a neutral safety switch and pin 30 on the ecu. Without this wire grounded I have found the car will NOT start when hot. It will crank just fine but wont give whatsoever. I've been looking over and over the ecu pinouts in my Haynes book and veryuseful site and cannot figure out exactly how this works. What exactly does pin 30 do? Is this pin suppose to be grounded when you have the trans in neutral while cranking? I see the gray/red wires go to pin 46 on the ecu and I have a feeling this should not be grounded like I have now. Can anyone give me some guidance??
thanks
Drew
thanks
Drew
