  • 1994 - 1995 Specific Tech
Edelbrock or Not
  • Thread starter Thread starter toyman
  • Start date Start date May 19, 2008
toyman
1,944
54
79
Vernon BC
May 19, 2008
  • May 19, 2008
Since I'm looking at a rebuild I'm trying to decide whether the cost of installing Edelbrock Heads (60259) vs a custom build of GT-40 heads is worth the extra $600/800. Anyone have any experience or knowledge.
I'm also confused why the Summit site shows the 60259 being applicable only up to the '85 model year. Is this just a listing error on their part? The Edelbrock site identifies them as Ford 289-351W Performer RPM Aluminum Cylinder Heads. I assume for all years.
Richard
StinkinLincoln
240
Louisiana
May 20, 2008
  • May 20, 2008
yea they will work, but heres the thing, those eddy heads dont have the best valve train parts...you will be having to upgrade the springs and what not, so get the bare heads and have some one assemble the heads w/ good parts.
FlyBy763
439
Palm Bay, FL
May 20, 2008
  • May 20, 2008
The intake valves are too big (2.02) to work with the stock pistons. You would have to put aftermarket pistons in or flycut your existing ones for them to work.
earleys94gt
1,223
Ashley, Ohio
May 21, 2008
  • May 21, 2008
You get what you pay for.
IMHO get the Edelbrock aluminum heads. In addition to flowing better than the stock heads, you will also get the benifit of shaving 50+ pounds off the front end.
Yes, you can do some custom iron heads, but they aren't as light as the aluminum one's.
Look on Edelbrock's web-site for the right part number if you are confused.
www.edelbrock.com
toyman
1,944
54
79
Vernon BC
May 21, 2008
  • May 21, 2008
I'm going with the Edelbrock 60529's as he has them on hand and is discounting them by about 20%.
So here's the program.
Labor
Strip Block. R&R cam bearings, frost plugs and oil gallery plugs. Hot tank block. Check align bore. Thread chase all bolt holes, flat sand gasket surfaces, Mag check block and reclean block after boring. Install cam bearing, frost plugs and oil gallery plugs.
Bore & finish hone with torque plate
Grind and polish crankshaft
R&R pistons and fit pins
Resize connecting rods with ARP bolts
Mock up crank & measure 4 corners, parallel deck block
Balance engine assembly
Assemble engine to long block
Replace engine assembly, install electronics and related items.
Parts
APR rod bolt set, main stud kit, head stud kit
Cloves 9-1254 True roller timimg set
Comp 1331-16 Promagnum roller rocker arms
Comp 1632-16 pushrods
Edelbrock 60259 heads
JB2205 roller lifters
MRG 3165G cometic MLS head gaskets
Probe 10682.030 Forged piston set 9.3:1 compression
CL CB634P.010 Con rod bearings SBF
CL SH510S cam bearings SBF
Comp 35 306-B roller camshaft 270HR
MAHLE 2M5523.030 Moly Plasma Ring set
These are the basics.
The EMS will be a AEM 30-1401.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
302 Engine build questions
  • Vulpes5.0
  • Apr 19, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2022
LEEDAY Boss
Planned Cross Country Run - 65 Fastback
  • Smokinstang65
  • Aug 17, 2021
5K
1965 - 1973 Classic Mustangs -General/Talk- Feb 27, 2022
Baron von K 289
