Edelbrock Performer RPM heads too much?
Rel
344
Los Angeles, California
I can possibly get a good deal on a set of these.
is the 2.02" intake going to give me some P/V clearence problems with my stock 302 and the following cam.
XE270HR - Duration @ .050" 218/224 | valve lift w/1.6 .512/.512
Would these be better than a set of 60379's?
The TFS twisted wedges with 2.02 valves can work with a stock block and most aftermarket cams. Just about any other 2.02 valve head will need the stock pistons notched for clearance. Now that's usually, you won't know until you check PVC with clay.
