Almost have the front end back together and I can't get the upper shock mount over the end of the shocks
The body is too big to slide up from the bottom and there is no way to twist the end back and forth like you normally do. The shock mounts upside down from traditional. I'm starting to think you need to use a 65/6 shock mount to get a little more wiggle room on the top. Anyone else run into this? Ideas?
To add insult to injury I have an appointment for an alignment in 9 hrs
