EDIS8 wiring help for 4.6
1stanger1
172
in my house
ok if this has been asked and answered i cant find it.....
get ready to read a whole bunch
my car was a 99 mustang V6 auto that i yanked out and dropped in a 93 mk8 4.6 dohc and a t45 trans the motor has a 96 cobra intake manifold and imrc runners that i deleted the butterflys but i never pulled the rod so i didnt have to fill in any holes.....
the engine harness is stock except where i modified it and made it 18" longer to be able to plug it in....
i am using a 96 cobra pcm, the pcm harness is from a 99 GT
everything was hooked up and so far so good till i found that i had to no power to my coils....so i went ahead and got me an EDIS8 and wire, made a bracket mounted it in the right side fender well
I wired up the coil packs and the crankshaft pos. sensor
So i have power to my injectors and the fuel pump.
Now i need to hook the rest of the EDIS up now the red/yellow wire is for a 12v switched on supply but i dont know where to hook up the other wires
GY/OR pip wire
OR/RD ign grnd
PK spout check connector
tan/yel idm/tach wire
i need to figure out what pins on the ecu these should be attached to
please if you have any diagrams or info please post here email or call me
[email protected] or 717-609-7391 or my 2-way 199*677*275
thanks
alan kendall
