EEC test problems PLEASE HELP!!!
With the way my car runs, i decided to run the eec test with jumper wire and voltmeter. I hooked the jumper wire and everything up right turned the key and the voltmeter just pegged out and stayed there. It would not move. I started the car with the jumper wire still in place and the car revved up to about 1600 rpm and slowly idled back down like it was searching for its idle. I can unplug the jumper while car is running and sometimes it just dies. Doest sputter or anything it just dies. What is wrong with my car???? Is teh wiring messed up? I get NO codes from koer or koeo tests. It just pegs the voltmeter out and doesnt move it. Maybe i need to change the voltmeters settings? Help me out!
don't you just use the check engine light? I'm not positive, but I don't even think you need a voltmeter to pull codes, I think all you need is that jumper wire, but I could be wrong... If you do need the voltmeter, you just have it set wrong.
thats true but thanks to my dad (i know hes not too smart but this was before his son *me* informed him of all the details on a computer controlled vehicle) the check engine light was removed, painted black lol and reinstalled. So in order to use that method i'd have to take the light out and replace it. Problem with that is the plastic piece of the dash that has the headlight switch and stuff on it is broken where it mounts to the dash. It is siliconed on there to keep it from falling off (for now) and i dont really want to have to take it off right now and re silicone it. This car was beatin to death its whole life until now when i'm trying to make it new again. Daily driven for 13 years. 191,xxx miles. So check engine light test is out.
Are you sure you have the voltmeter connected properly?
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
have the voltmeter connected properly? follow these links for help>
mr_tinkertrain said:
if i touch the two ends of the voltmeter together the needle moves so i'm pretty sure its set correctly. I can change the settings but the needle still only moves so far then it just stays there. there is no movement of the needle.
Sounds like you are using the Ohms function. Ohms are for measuring resistance and checking fuses. Don't use Ohms to measure a powered up circuit or you risk damaging the meter.
Select the voltage function or follow the link in my previous post & use a test light.
Youre right i was using ohms but i switched to voltage with no change. It still does the same thing. Maybe i'm using the wrong plug. I KNOW i have the eec test plug but i'm not absolutely sure i have the correct small plug the jumper wire is supposed to be ran to. The plug i have has 2 wires running to it, not just one. So which side am i supposed to use? It is located in the driver side engine bay just behind the shock tower along with the EEC plug. Can someone get me a picture of the plugs?
The probablity is that you have some wiring problems.
The black/white wire on the self test connector is signal ground for the
computer. With the ignition switch OFF, measure the resistance between the
black/white wire on the self test connector and ground. You should see less
than 1 ohm. More than 1 ohm means some bad connections. More that 1000
ohms is some broken wiring.
Diagram courtesy of Tmoss and Stang&2birds.
The next steps require you to remove the passenger side kick panel and then
remove the wiring connector from the computer. A 10 MM socket is needed
to get the computer connector off.
Mesure the resistance between the STI (pigtal connector and pin 48 on the
white/red wire on the self test connector pigtail and and pin 48. You should
see less than 1 ohm. More than 1 ohm means some bad connections. More
that 1000 ohms is some broken wiring.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
