EECIV CODE GURU's Needed in here please
  • Thread starter Thread starter BlackSunshinelx
  • Start date Start date Oct 7, 2004
BlackSunshinelx
86
long island,ny
Oct 7, 2004
  • Oct 7, 2004
I keep throwing codes 31,67 and 85 and i dont know why. I know why i'm getting the 85 and thats because i dont have a CANP solenoid i took it out, but the EGR code is buggin me.ANy ideas on what i can do to fix them?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 7, 2004
  • Oct 7, 2004
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref missing or broken wire or bad contact in circuit. Check for 5 volts on the orange/white wire. With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Use the black/white wire for the voltmeter ground. Check for the same results on pin 27 on the computer. Check for continuity between the wiring at the sensor and the computer. The brown/lt green wire on the sensor & pin 27 should be less than 1 ohm. The black/white wire on the sensor & pin 46 should be less than 1 ohm. The orange/white wire on the sensor & pin 26 should be less than 1 ohm.
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. You can generally ignore this code, since it has no effect on engine performance.
M
mikealdcorn
  • Oct 7, 2004
help me
i got lots of codes my car is straight messed
code 81,82,84,95,15 and when runnin code 41, 91 ,33
sorry for hijackin the thread
04-SVT
53
Las Vegas, NV
Oct 7, 2004
  • Oct 7, 2004
mike...
check your EGR system, vacuum lines and such, you possibly have a sticking EGR valve or faulty EVP (sensor that mounts on top of your egr valve)
With all those lean codes and fuel lpump circuit codes, I would have to check your fuel pump relays, if they look ok, your pump maybe on its last breath
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 8, 2004
  • Oct 8, 2004
mikealdcorn said:
help me
Code 15 - No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure). The voltage to the Keep Alive Memory (KAM) is missing (wiring problem) or the KAM is bad. The KAM holds all of the settings that the computer "learns" as it operates and all the stored error codes that are generated as a result of something malfunctioning while the engine is running. Use a voltmeter to check the voltage to the pin 1 on the computer - you should always have 12 volts. No constant 12 volts = bad wiring. If you do always have the 12 volts, then the KAM is bad and the computer is faulty.
Wiring diagrams for the proper model years are next…
For 86 models see http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
For 87 models see http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
For 88 models see http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
For 89-90 models see http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
For 91-93 models see http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See http://www.veryuseful.com/mustang/t...ng5.0Vacuum.gif for help on the vacuum line plumbing.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. The dump valve air diverter valve (front vacuum operated valve) isn’t working on the Thermactor Air System (smog pump). Look for broken or missing vacuum lines on the solenoid valve to the diverter valve Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
Code 84 - EGR Vacuum Regulator - Solenoids. The EGR vacuum regulator solenoid is inop, missing vacuum, broken vacuum lines, vacuum leaks, or bad electrical wiring from the computer or no power to the solenoid.
Code 95 - Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
For 87-90 model cars, to help troubleshoot the 95 code, follow this link for a wiring diagram http://www.veryuseful.com/mustang/tech/engine/images/fuel-alt-links-ign-ac.gif
For 91-93 model cars, help troubleshoot the 95 code, follow this link for a wiring diagram http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif
Also see http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp
Check the black wire that comes out of the tank; it is the fuel pump ground. It goes to a 2 wire connector and then ground to the chassis. If the connections get dirty or corroded, you will lose fuel pressure.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines. Check to see if you have 5” of vacuum at the EGR vacuum connection at cruse RPM. Look for electrical signal at the vacuum regulator solenoid valve located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Code 41(Right O2 sensor) or 91 (Left O2 sensor) - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel.
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
The O2 sensor ground is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than .4 volt. Remember lean = less voltage.
" When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than .6 volt. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage."
Charles O. Probst, Ford fuel Injection & Electronic Engine control
Codes 84 & 33 aire part of the same system - EGR. Fix the 84 code and the 33 will go away.
M
mikealdcorn
  • Oct 8, 2004
thanks for that last post
my cars a 88 with a mass air conversion done to it and its never ran right since so i got the wirin wrong thanks for post .
peac
W
wing_t_00
9
  • Oct 10, 2004
I am getting a code 29 which is the vehicle speed sensor, but i do not have cruise control. Some places I have looked say that you only need that if you have cruise control. Any help would be great.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 10, 2004
  • Oct 10, 2004
Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. The VSS is used to tell the computer to speed up the idle as you slow to a stop. This helps keep the engine from stalling when you slow down for a stop sign or stop light.
Check to see if the electrical connector is plugged into it. Cost is under $30 and it is easy to replace.
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Saturday at 1:59 PM
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 1:59 PM
Machbud
M
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
