mikealdcorn said:
help me
i got lots of codes my car is straight messed
code 81,82,84,95,15 and when runnin code 41, 91 ,33
sorry for hijackin the thread
Code 15 - No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure). The voltage to the Keep Alive Memory (KAM) is missing (wiring problem) or the KAM is bad. The KAM holds all of the settings that the computer "learns" as it operates and all the stored error codes that are generated as a result of something malfunctioning while the engine is running. Use a voltmeter to check the voltage to the pin 1 on the computer - you should always have 12 volts. No constant 12 volts = bad wiring. If you do always have the 12 volts, then the KAM is bad and the computer is faulty.
Wiring diagrams for the proper model years are next…
For 86 models see
http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
For 87 models see
http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
For 88 models see
http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
For 89-90 models see
http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
For 91-93 models see
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See
http://www.veryuseful.com/mustang/t...ng5.0Vacuum.gif for help on the vacuum line plumbing.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. The dump valve air diverter valve (front vacuum operated valve) isn’t working on the Thermactor Air System (smog pump). Look for broken or missing vacuum lines on the solenoid valve to the diverter valve Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
Code 84 - EGR Vacuum Regulator - Solenoids. The EGR vacuum regulator solenoid is inop, missing vacuum, broken vacuum lines, vacuum leaks, or bad electrical wiring from the computer or no power to the solenoid.
Code 95 - Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
For 87-90 model cars, to help troubleshoot the 95 code, follow this link for a wiring diagram
For 91-93 model cars, help troubleshoot the 95 code, follow this link for a wiring diagram
http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif
Also see
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp
Check the black wire that comes out of the tank; it is the fuel pump ground. It goes to a 2 wire connector and then ground to the chassis. If the connections get dirty or corroded, you will lose fuel pressure.
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines. Check to see if you have 5” of vacuum at the EGR vacuum connection at cruse RPM. Look for electrical signal at the vacuum regulator solenoid valve located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
Code 41(Right O2 sensor) or 91 (Left O2 sensor) - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel.
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
The O2 sensor ground is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than .4 volt. Remember lean = less voltage.
" When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than .6 volt. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage."
Charles O. Probst, Ford fuel Injection & Electronic Engine control
Codes 84 & 33 aire part of the same system - EGR. Fix the 84 code and the 33 will go away.
