EEK!!
Roos
24
so today i changed the oil and i went to check it to see if i needed to add a tad more and what not and the dip stick holder thing came with the dip stick??......is this ok to drive with out that in there?....and where does it go i looked all over but couldnt seem to find it....
you should be able to do it yourself relatively easily. Just put it back in the position it was and push down on it to get it started. After that it gets a little tougher. I made a custom "thing" to tap it in the rest of the way. Just use something that you can push or hit on to help get it seated.
i got it in...i just couldnt find the hole and didnt know exactly where to look but i jacked it up again took a look and found it....the last thing i wanna do is blow it up lol...thank for the help
