Digital Tuning Efi Conversion In San Diego
  • Thread starter Thread starter engarom
  • Start date Start date Aug 11, 2012
E
engarom
29
  • Aug 11, 2012
Hi all,
I am stuck on my EFI conversion and i need some professional help. I have everything sorted out and it actually starts but idles and runs like crap!
I cant figure it out so i want to take it to someone who can. Does anyone have a recomendation of a good Mustang shop in San Diego CA?
Thanks
1965 Mustang Fastback, 302 roller motor from a 91 mustang, T5 Trans, 93 Cobra intake.
mustangmutt
339
El Paso, TX
Aug 12, 2012
  • Aug 12, 2012
What type of EFI system did you use?
rbohm
6,698
550
204
tucson,az
Aug 12, 2012
  • Aug 12, 2012
assuming that you used the factory ford EFI system, start by checking the wiring, specifically the injector wiring. if you used an HO 5.0 efi system, the firing order would be 1-3-7-2-6-5-4-8. sometimes people forget this and use the older ford 1-5-4-2-6-3-7-8 wiring, and of course the engine runs like crap. and that is what it sounds like you might have done. also check the ignition wiring as well.
after that go back through the electrical system, and clean every plug, both sides, ans reconnect them remembering to use the dielectric silicon grease ford used to waterproof the connectors.
from this point check the simple things like vacuum leaks, plugs, valve lash, etc.
you might also have the injectors flow tested to make sure they are putting out according to spec.
E
engarom
29
  • Aug 13, 2012
Thanks for the suggestions. I am using factory EFI. I have been through the firing order and am actually using all the parts from the same donor so it should be correct. I have been through all the connections a few times. everything seems to be in order. Starts and idles. Idle is a little erratic. Stutters under throttle and bucks when driven. can only get 5mph bucking and lurching down the street.
I have eliminated all the EGR and smog crap. All vacuum connectors with the exception of the PCV, and fuel regulator have been capped.
Any other suggestions!
Thanks
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 13, 2012
  • Aug 13, 2012
The first step should be to pull the codes from the computer. What codes are present on the KOEO and KOER tests?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 13, 2012
  • Aug 13, 2012
There's a guy on the Fox 5.0 tech forum, JRichker, that has helped me in the past on my fox 5.0. You can start with this link and if you run into issues just PM jrichker:
http://www.stangnet.com/mustang-forums/threads/help-me-create-the-surging-idle-checklist.698148/
golf4283
1,253
Orland Park, Illinois
Aug 14, 2012
  • Aug 14, 2012
When removing the EGR and smog did you make sure to fool the computer into thinking it's present? I believe the system goes into limp mode when EGR isn't present without a resistor being isntalled.
After that start by unplugging the TFI module as well as the IAC valve.
Start the engine
set the idle at 550-600
time the engine to the stock specifications (don't advance it, the computer will do that for you)
reset the idle if it has risen.
plug all sensors back in.
I know when I did my conversion I forgot to set the base idle and it was acting really weird until I got it all set properly. I also was setting the base timing with the IAC valve plugged in which is not the correct method either.
Hope this helps. You don't need a shop. Just keep asking questions and you'll get it right. Save the money for something else.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 14, 2012
  • Aug 14, 2012
Make sure you disconnect the spout connector when setting the timing
E
engarom
29
  • Aug 15, 2012
Thanks for all the advice.
I bought the harness from some guy on ebay. He says the EGR resisters ar e installed to fool the computer.
I will try the suggestions from above and see if i can get it sorted out this weekend.
Thanks again
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
F
C4 Transmission
  • Fri Guy
  • Jan 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
LILCBRA
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
88 Foxbody Starts but Stalls When Warm Please Help
  • airforcerob
  • Apr 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
K
Engine 93 gt new 351 w moter put in and installing ace's kill shot EFI. It turns over but Wan't start? Need Help.
  • kimscales
  • Jun 1, 2024
Fox 5.0 Mustang Tech Jun 2, 2024
AeroCoupe
