To all of you conversion people. I have one question I have to ask again; pertaining to one specific wire and how to deal with it. There is a solid yellow wire that was connected to the "A" pin on the regulator. I have removed the regulator obviously, but where/what do I do with it. The wire was also in series with a black and yellow wire that is all part of the "charging/power" circuit. The Black/yellow strip wire I traced to the 20A fuse on the block (it was labeled Cigarett Lighter). I just spliced this one into a constant hot off of the solenoid. How/where do I connect the yellow wire in the new harness ('91 GT w/ AOD). I have a three fuseable link supply (cut out of the '91) that connects to the constant hot side of the solenoid, and I wanted to know if this is where I splice in? This is the LAST set of wires that I have to deal with and for the life of me cannot figure it out. Someone has to know.... help. Thanks
