EFI or Carb??
wieberacing
Does anyone out there know how hard it is to swap a 94 mustang gt out to carburation? Also does anyone know approximately how much it would cost and how much work would it be?:shrug: I am really tired of messing with the computer so i was thought i would check and see what it would take. Any advice would be appreciated.
IMHO- going to a carb setup from EFI is REALY not the thing to do if its going to be any kind of street car.
EFI (even our red headed step child of an eec) is realy not that hard to work with and you will get tons better mpg, smog will be pass-able, better throt. response (in general). Yes it may cost you 500-ish$ to get the eec properly tuned or to get a tuner and spend some time learning.
Carb's- well they are better suited for track cars and can be driven on the street. You will have a big PITFA if you need to pass a smog test. MPG will nto be as good as EFI. The cost may look like it will be cheaper to just go carb but sit down and to do it right with good parts will cost more than getting a tune. An ex. carb intake, demon or holly carb, dizzy, re-wire, fuel system from the high press efi to low press. carb stuff. It will nickle and dime you way past the point of just getting things sorted out now.
P.S. What is your problem with the car now as far as tune and issues that makes you think the swap would be better? I am trying to see if there is a way for the great amount of help here to get your setup working properly.
I'm a dinosaur. I cut my teeth on cars when fuel injection was exotic, mechanical, and expensive race car stuff. I'm in the process of doing a efi to carb swap on a '92 F-150. However, I would not convert my 'Stang over to carb without a really good reason. I agree with blksn955.0 and therian that you are better off fixing the relatively minor computer problems with your car as it sits than switching to a carb. Think about it--you would need to get a carb, manifold, gaskets, new distributor with mechanical/vacuum advance, throttle bracket, throttle cable, fuel line and fittings, fuel pressure regulator and possibly a low pressure fuel pump. If you have an AODE you need a transmission controller like a Baumanator. I can see a minimum $1000-$1500 right there depending on how much you can buy used. In addition, you're going to have considerable time and aggravation in getting it all hooked up and working properly. With that kind of investment you could ship your car somewhere and have it tuned.
What kind of tweecer or tuner could i get so that i could tune it myself? I thought you couldnt get a tuner for the eec IV computer. Fuel mileage and smog emissions arent important because im from Kansas and we dont have many emissions laws here. I wanted a carb so that I could tune it myself instead of everytime i changed something that i would have to get the computer retuned which could cost a couple of hundred bucks each time and that might add up after a little while.
For the self tuner route you have quite a few choices.
TweecerR/T- dont waste your time with the base model you NEED the datalogger that comes with the R/T to know what your changes are doing--$550
PMS- alot easier as far as user friendly-ness--I think its about $650-750-ish???
SCT pro-tuning software- Higher end newer unit that has dealer support cost ???? I heard 800$ or so but I dont know.
We have a tuning section, I would search each tuner out by name and see what you think and ask questions there.
