Since I got the car I have always gotten code 33 (EGR not opening properly). I tried switching the EVP sensor and even cleaned out the EGR (which had lots of build up in it) but I still get code 33. So, I pulled of the vacuum line to see if there was any suction. I didn't feel anything. Is this normal or might this be causing my problem? All I know is that there is a vacuum line that runs from the intake to a solenoid on the passenger side shock tower and a vacuum line runs from there to the EGR. What is the purpose of that solenoid? What might be causing the problem here?
With my TPS, I stuck a volt meter on it to get it adjusted properly. I tested it with the key on and engine off. For some reason, I could not get the TPS to go below 1.25V. Does this mean the TPS is probably junk?
