EGR Help
  • Thread starter Thread starter teal94_stang
  • Start date Start date Dec 30, 2009
teal94_stang
18
Marshall, Michigan
Dec 30, 2009
  • Dec 30, 2009
First off i just want to introduce myself, my name is Brian and I am new to the forums. Second, i found out before winter i had an insufficient EGR valve. I would prefer to just eliminate it since i deleted the smog and a/c last winter. Do I just find a way to keep the plunger down? Do i leave the wires plugged right in or do they come out? Will it throw any codes this way?
thanks
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 30, 2009
  • Dec 30, 2009
Well, first off the EGR only functions at part throttle; it has no effect on WOT so all it's doing is adding weight. If you chose to remove it, you can try to hold the plunger down halfway or you can get a chip for the computer to simply turn off the EGR check. Simply removing the EGR without a chip will definitely throw a a code.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
