egr plunger
  • Thread starter Thread starter a_k
  • Start date Start date Aug 15, 2005
a_k
170
Saratoga NY
Aug 15, 2005
  • Aug 15, 2005
what's up, i'm going to be putting on some ford header gaskets soon since the mac copper ones are leaking. I know there is no bennifit from removing the egr but it's less clutter, one less thing to leak or go wrong, and besides I think the tube is a pain in the ass. So if I use a wire crimp to hold the plunger down half way will this have the same effect as deleting it through the computer? I don't want denotation and i'm going to get it i'll leave it on.
Thanks
Adam
btw I searched and didn;t find the answer so...
legalize420
1,541
South Florida
Aug 15, 2005
  • Aug 15, 2005
Thanks
Adam
i recently did the same thing. swapped the leaking copper ones out. my egr was leaking so i capped it off and used the plunger method. im not sure how far i pushed it down but i used the cap from the locktite, a rubberband, and some elec tape . i doubt its the same as takinging out of the computer. i ended up putting the egr back on this weekend and i like the way it drives better with it on. i think its the mac headers bung that is probally off a tiny bit. i read a post a while ago with a suggestion of cutting the tube and putting a piece of heater hose in betwwen so it can have a slight flex. thats what i did this weekend since the brand new tube that i bought did not even line up. either way good luck
legalize420
1,541
South Florida
Aug 15, 2005
  • Aug 15, 2005
your car probally sounds good
a_k
170
Saratoga NY
Aug 15, 2005
  • Aug 15, 2005
thanks.
I like the idea with the heater hose, since I removed my air pump I have some lying around
a_k
170
Saratoga NY
Aug 23, 2005
  • Aug 23, 2005
I ended up just taking it off. turns out it was leaking out of the tube. The car runs the same with no egr and the leak is fixed.
HISSIN50
34
129
Aug 23, 2005
  • Aug 23, 2005
This just keeps a CEL from tripping. One can still get part throttle detonation with the plunger trick only.
To do it right, one has to turn the EGR function off inside the computer, via a chip, tuner, etc.
Good luck.
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
