EGR Question
  • Thread starter Thread starter teal94_stang
  • Start date Start date Jan 2, 2010
teal94_stang
18
Marshall, Michigan
Jan 2, 2010
  • Jan 2, 2010
First off my name is Brian, I am new to the forums. I found out before winter that my car has an insufficent EGR valve. I really like the idea of just eliminating it since i got rid of the smog and A/C. How do you do this with out the car throwing a code?
HankyGT
81
Warren, OH
Jan 2, 2010
  • Jan 2, 2010
Just block it off with either a homemaid EGR blockoff plate or store-bought, the vac lines going to the smog fitting and run your smog eliminator pulley. Then simply unplug the EGR from it's harness.
You won't throw any codes at all that way.
4Jenna
4,326
AZ
Jan 2, 2010
  • Jan 2, 2010
1994 1995 Mustang Pulleys and Parts
Bottom of the page
-Chris
HISSIN50
34
129
Jan 3, 2010
  • Jan 3, 2010
If you don't generate a code and you block off the EGR passageway, you chance a part-throttle detonation issue.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
