  • 1994 - 1995 Specific Tech
EGR Removal
  • Thread starter Thread starter Danman765432
  • Start date Start date Feb 6, 2008
D
Danman765432
471
Nutley, NJ
Feb 6, 2008
  • Feb 6, 2008
I was just wondering how you guys wound up getting your EGR off? I need to take it off to get clearance to get my head out. So if anyone has any input just let me know.
G
grngt50
250
Los Angeles
Feb 6, 2008
  • Feb 6, 2008
I assume your talking about the nut holding the egr pipe to the headers.........if so, I took an adjustable wrench and a hammer and went to work. Just make sure you've got the wrench clamped on super tight because they love to slip and strip.
-James
ronstang94
204
Phx, AZ
Feb 6, 2008
  • Feb 6, 2008
The best and easiest way to get the the EGR tube off is to use a crows foot (not sure if that is the real name or slang, google it) an extention or two and a socket wrench. Keeps your hands out of the tight space, and it is so easy.
Methodical
1,192
11
59
Clinton, MD
Feb 7, 2008
  • Feb 7, 2008
Put antiseize on once you get it off for future removal.
94Blue302GT
704
Chicago
Feb 7, 2008
  • Feb 7, 2008
Cut pipe
Pinch closed
Ditch EGR and pump
buy chip/tuner for more power and EGR delete
Enjoy performance
D
Danman765432
471
Nutley, NJ
Feb 8, 2008
  • Feb 8, 2008
Just a quick question...Can you just remove the upper part by the nut...I just need clearance to get the heater hose off the lower intake and I cant get to it....I dont remember what I did to get it off when I did my intake swap
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Feb 8, 2008
  • Feb 8, 2008
I took a pipe wrench to the nut on the header, and then unbolted the whole assembly from the upper manifold...
D
Danman765432
471
Nutley, NJ
Feb 8, 2008
  • Feb 8, 2008
I am able to get my passenger head off, if I did not have the egr in the way...I need to figure something out to get it off....
Did you guys try to take it off from under the car or above? Also mine is rusted to **** and I have been using pb blaster on it.
G
grngt50
250
Los Angeles
Feb 8, 2008
  • Feb 8, 2008
from up top........just keep at it you'll get it. It only took me a minute or two to dc it from the header.........and I'm the type of guy who has problems with EVERYTHING on this car. Just be patient and it will eventually work out. Did you try the crescent wrench/ hammer combo yet? It's not the prettiest/craftiest method, but it gets it done quick. Good luck man
-James
gcomfx.com
3,690
Republic, MO
Feb 12, 2008
#10
  • Feb 12, 2008
  • #10
You can heat it with a torch. Even a propane one will work.
D
Danman765432
471
Nutley, NJ
Feb 16, 2008
#11
  • Feb 16, 2008
  • #11
What size is the nut by the header for the EGR...I am just wondering if I should get a metric crows foot set or standard?
Thanks,
Dan
ronstang94
204
Phx, AZ
Feb 16, 2008
#12
  • Feb 16, 2008
  • #12
I just went out and checked what size it was that fit and both the top and bottom nut on the EGR tube are 1". With the crows foot, extension, and socket wrench set up you also have enough room to use a breaker bar for extra torque to get it off. Some Liquid Wrench super penetrant will also help.
D
Danman765432
471
Nutley, NJ
Feb 17, 2008
#13
  • Feb 17, 2008
  • #13
Thanks a lot...I was going to get the crows foot set from northern tool but it doesnt go up to 1 inch so I guess I am spending $40 on the craftsman set.
Bosko5.0
1,067
longwood, FL
Feb 17, 2008
#14
  • Feb 17, 2008
  • #14
I thought it was a 24mm??? I just used a cresent wrench/hammer the first time. turned it both clockwise and counter clockwise to loosen it up Myne also was rusted up.
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Help--Need New Exhaust Gas Recirculation (EGR) Tube for 1994 V6 3.8 L Mustang--where can I find one?
  • DPP
  • Jun 5, 2025
1994 - 1995 Specific Tech Jun 10, 2025
DPP
D
