EGR Spacer
  • Thread starter Thread starter lgbnaf7
  • Start date Start date Aug 23, 2005
L
lgbnaf7
61
Tacoma Wa
Aug 23, 2005
  • Aug 23, 2005
Can anyone give me some suggestions on how to take the EGR spacer off? The Throttle body was easy the spacer is giving me hell.
txstang84
1,639
42
69
Tuscola, tx
Aug 23, 2005
  • Aug 23, 2005
rap on it mildly to moderately with a mallet-not a hammer...often the corrosion caused by non-distilled water in the coolant will keep if from coming off as easily as it should.
if you can remove the studs, that would be even better, then you can just tap it straight up or down and it would pop right off
txstang84
1,639
42
69
Tuscola, tx
Aug 23, 2005
  • Aug 23, 2005
...you could also score the area between the mating surfaces with a putty knife or common screwdriver, that could help you out a little. if you can manage to get one slightly wedged in between the spacer and the intake body, just "walk" it around slowly, and it should help loosen up the crud that is no doubt holding your spacer hostage...the only reason i don't recommend using a razor blade is for the inherent slicing-your-finger-off factor
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Aug 23, 2005
  • Aug 23, 2005
that thing is a bitch alright. i ended up prying mine off with a screw driver and taping it with a rubber mallet
L
lgbnaf7
61
Tacoma Wa
Aug 23, 2005
  • Aug 23, 2005
thanks
I got it off with a whole lot of prying and some good old fashion elbow grease.
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
Aug 23, 2005
  • Aug 23, 2005
good stuff....... you should se how hard an old water pump can be. my buddy broke my timing chain cover trying to get mine off
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
SOLD Ported GT40 tubular upper and lower
  • Kid wita 5oh
  • Nov 11, 2025
  • Engine and Power Adder
Engine and Power Adder Nov 11, 2025
Kid wita 5oh
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
