Elbow Deep in Dex!!!!! 56K Warning.
69Rcode_Mach1
1,473
Salt Lake City, Utah
I finally took the tranny apart. I bought it rebuilt off of corral. I verified that it is a T-5Z by counting the number of revolutions of the input shaft and the 1st gear. It was 3 turns exactly. So it must be the 2.95 which is the Z-spec. Anyway the thing was having problems going into gear, sometimes it went right in and sometimes it was like hitting a brick wall and would not go in. I called D&D they said it was a clutch issue, which means my stupid hydraulic clutch wasn't disengaging, but it could be synchros, or bent shift forks which is unlikely. But while it is out I would like to have the peace of mind to make sure it is built right. Anyway I want to check out the synchros and shift forks to make sure that the internals are okay. Here are some pics for you guys. I have some vids but don't know how to put them up. I am searching to find them. Here are the pics.
http://videos.streetfire.net/player....7-BA7C096E18A0
http://videos.streetfire.net/Player....9-E196664AC2C1
http://videos.streetfire.net/player....A-4F6A307BDC60
http://videos.streetfire.net/player....7-63C75DA7DEE2
I don't plan on having this tranny last much longer than a year or two at the most before my engine grenades it. Then I am upgrading it with a G-force. This is just temporary but it has to work. Hope these vids help. I want you guys to help me spot anything out of the ordinary. I am hoping it was just the clutch not disengaging properly.
looks good to me, First gear is the largest gear toward the rear of the trans, the syncros look good in the pick, they look new, check the 1-2 slider, look toward the inner diameter of the slider and check the teeth that mate up to the first gear syncro. They should be pointed and not rounded over.
I had problems with the slider teeth being worn and not engagine the gears as they should, of course this was 2nd gear, things are different for first gear since the car is usually at idle when it engages. Did you ever try downshifting into first when the car was already moving?
i dunno if this helps but, i just put my t5z in this week, and it felt a little notchy in 1st and 2nd........it went in ok, just a little stiffer than 3rd and 4th......i turned my fire wall adjuster out one more turn and it seemed to help it some......
thats the problem with a hydraulic clutch.......it's harder to 'feel' what the clutch is doing.....
damn man.......lets see here, with a .63 overdrive 5th gear (t5z 5th gear) and a 2.75 rear end gear......your cruise on the freeway will be what like 1200 rpms??? lol...you'll be idling......:D
