Electric Fan Options
What radiator do you have now? Does it overheat? Do you have AC?
Mine was fine with a stock copper/brass 4-core radiator until I added AC. It would overheat in traffic. Then I swapped in an aluminum crossflow radiator and Taurus fan. Then I had low voltage issues at idle. So I swapped in a 160A alternator.
So...If you go big on the fan, plan to go big on the alternator (and all the associated wiring, circuit protection and relays). On the other hand, you don't want a wimpy fan that can't handle high summer temps at idle in traffic.
If you have the anemic stock alternator, then a better one is a very good idea. You shouldn't need a new radiator if the engine cools fine right now. Look into the Lincoln, Taurus, and '94+ Mustang OEM fans. They pull tons more air than even a Black Magic(or Black Tragic as I have heard it called).
I actually think a thermostatic fan clutch would be better. That is probably what I will go with after I get an aluminum radiator.
No I haven't had overheating issues with the current radiator. It's just the stock one that came with a 289. I'm putting in the 302 now and although I don't know how the radiator will work now, my guess is it should probably perform fine. However I do want a cooling system that will support a high horsepower (350-400) engine later down the road. My alternator, to the best of my knowledge is what came stock on a 289.
EDIT: I had an old A/C system but I'm scrapping it. It never worked right in the first place. During the years of driving it I got acclimated to Texas summers w/o A/C. :D
For 350-400hp, a better radiator will be mandatory. I have a fairly new 3-row in my '68 and it's not enough if the outside temp is over about 85°. The water temp will keep slowly climbing it takes a long downhill to get it back down to ~190. Below 80, though, it cools just fine.
Hello guys,
i needed better cooling for my 331 (5.0 roller base block) too. First i installed a 3g alternator and opened the radiator support for a 2 row mishimoto (fox style) aluminium radiator. Following a edelbrock victor water pump (clock wise) and a set dual spal fans. They controlled by a spal fan controller.
No more overheating problems :nice:
coooooooool greetings :D
Markus
x2
mine did exactly the same thing with a 300rwhp 306.
Ended up putting a griffin radiator and the fan was rarely on except during the summer and not moving . . . even with a junk hayden fan.
I forgot to mention that I also have a fan shroud and it still doesn't cool that well. The fan is a stock 5-blade flex, but it still pulls a lot of air.
Having a really good radiator means less airflow is needed to keep things cool so the fan doesn't have to be that great. I put a 31x19" Northern aluminum in an '89 GT I used to have and it stayed rock steady at 195° even with a bad fan clutch in 110° weather going up a hill with the A/C. That was with the same engine that is in my '68 now. I hate to think how fast it would heat up if I got the A/C working...
