Electric Fan Question
CKYlndSpd21
34
Okay so I put in an electric fan from a Taurus and went with a cheap fan controller from autozone. Well the fan ate up that controller so I want to use the right controller so I never have to mess with this again.
Everyone rants and raves about the DCC unit. I'm most likely going to order this but I have a few questions first. First off the FK35 is the correct model i need right? Next if I install this do I need to put in an added relay of any kind? Will this control both speeds on the fan? And finally does anyone have a write up of how to correctly install this thing?
PS I searched google and came up with this. Is this the easiest way to order the fan?
Corral Forums - View Single Post - DCC Access
Yep
Yes that is the setup you want. The DCC comes with instructions and a picture to follow.
You do not need a relay and you only need to hook up the high speed leads on the fan (it has 3 wires) because the DCC gradually increases power as the temp probe tells it your car needs more cooling.
You will need a 3G alternator if you don't already have one.
Very easy install and the kit comes with all the wires and connectors you will need.
on my 86 I just put a switch inside the car. Never turned the fan on when on the freeway. Traffic I just left it on
Switching a fan on and off manually is a bad idea. Too many guys have been distracted (hot girl kissing on their neck, too much to drink, dog tired and not thinking clearly) and cooked things because they forgot to flip the switch. An equal number have forgotten to turn the switch off for the same reasons and run down their battery.
If you don't have a high current alternator, you can forget about using an electric fan. The stock 65 amp alternator on 86-93 Model Mustangs isn't big enough to run the fan and the rest of the car.
3G 130 amp alternator installation instructions: Stangnet 3G install sticky 3G Alternator Install: A How To - Mustang Forums at StangNet
The best fan controller available today is a DC Control unit. Now serving. Cost is about $110. Be prepared to wait 4 weeks or more to receive your controller once you have sent in your payment. The controllers are custom made in small lots and lead times can stretch out.
Next best is a SPAL controller - $70-$90 See http://www.spalusa.com/fans/automated/accessories/fanpwm.html. Ebay will have the controllers for the $70: do a google search and see what you find.
At the bottom are the Hayden or Imperial controllers available through Advance Discount Auto Parts and AutoZone. The non adjustable one is about $30 ( Hayden 226206) and the adjustable one is about $60 (Hayden 226204). I recommend you do a Google search on Hayden and the part number for more info.
Do not use a simple on/off switch without using a relay. The current load can burn up the typical cheap automotive switch very quickly. The fan draws 30+amps and you need to use #10 wire on the fan power and ground wiring.
If you are good with electrical stuff (90% of the people here aren't), build your own controller. The numbers on the diagram (#86, #87, etc) refer to the numbers on the bottom of a typical automotive relay.
attachment.php
Note that the thermostat switch in the diagram isn’t really suited for the job. You’ll have to do a Google search and find your own.
This version of the fan controller will continue to run the fan after the ignition switch is turned off, just like most new cars.
To allow the ignition switch to control the fan so that it does not run when the ignition is off, connect the relay contact #86 to the red/green wire on the ignition coil or to the red/yellow wire on the coolant level sensor.
attachment.php
If you are an experienced electronics tech or electrical engineer, email me and I will send you the prototype drawings of a fan controller that is probably as good as the DC Control unit. It is a build it, troubleshoot it yourself item. I will not build or troubleshoot units, so it is not suitable for anyone who isn't really good with electronics.
Alternate placement for a temp gauge sender or temp switch/temp sensor for an electric fan. Use the heater feed that comes off the intake manifold. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. Be sure to use the same water feed line as the ECT sensor. That way you will get the most accurate temp readings.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
attachment.php
