Electric Fan?
MY 85 GT
1,852
208
104
New Jersey
I have the stock clutch fan still i want to take that off and put an electric fan on which is the best to get? My GT is an 85 ....so what type would be good.....And do they really add HP...
The Black magic is marginal at best, if you want the baddest fan ever created get a Mark VIII fan.
Yep....second only to a Viper fan, and good luck finding one of those in the local pull and pay :rlaugh:
Seriously, don't waste money on aftermarket fans. There isn't a single one of them that'll move as much air as the Mark VIII fan and you get OEM reliability and you should be able to get one for $20 or less from a junkyard. I paid $15 for mine.
Also they don't "add" hp but they can free up parasitic hp loss that you get with the clutch fan or a flex fan. I've *heard* as much as 35hp but that sounds like BS to me.
Yeah the elec fan was the first thing I did when my car was bone stock with the air silencer still on, in lower rpms I didnt feel anything, but there was a noticable difference at the top end and gas mileage increased a little bit.
Why no mention of a SN95 fan? Aren't these any good?
Probably because the Mark VIII is just that good. It almost moves 4500cfm of air at full speed....there's just nothing out there that's that badass. Most aftermarket fans don't move more than 2000cfm.
Look at how well it fits a radiator....all you do is trim 1/2 inch of the depth of the shroud off with a jigsaw and they slip right in. They don't work with supercharger setups where you have extra pulleys and belts, but with a stock or N/A setup they're almost impossible to beat.
Most say that the Taurus fan works well too, even on the lowest speed, but i liked the shroud of the Mark VIII better.
As far as 94-95 fans, the V6's had one speed fans and the GT/Cobras had two speed fans. There were issues with the high-speed fan motor and the wiring connectors. I'd rather have a 3.8L Taurus fan instead (I actually have a Taurus fan on my 94 GT).
To the OP, since you were willing to spend some coin on an aftermarket fan, get a J/Y version of your choice like everyone suggested, and then spend the extra cash on a Delta Controller.
Good luck.
Thanks guys for all that info....Im wondering if that fan will fit if and when i bolt up my B&M 144 blower? If not i need to get a slim type of electric fan....And do they make kits for the 3G alt....????
What about the Black Magic Extreme?? Anybody using it?
I have it, as 85 SS said its a good fan but you don't need to spend 300 (mine was 270 from Brothers) when you can get the MarkVIII fan for cheaper but I wanted it for underhood bling also and I didn't want to wait for a DC controller and do lots of wiring myself. My friend has the 1st gen Black Magic and this Extreme blows much harder and has a much better shroud that covers more radiator surface. My motor has no problem staying cooler than the 180 t-stat with a stock radiator and water pump.
