electric problem please help
  • Thread starter Thread starter jvann07
  • Start date Start date Aug 3, 2005
J
jvann07
cincinnati
Aug 3, 2005
  • Aug 3, 2005
I have an 89 gt convertable with every electrical problem you can get. The car now has a newer, cleaner harness but still major ploblems. I live in Cincinnati, Oh looking for a shop or someone with knoledge to assist me fix this problems. the car cranks but will not start, the lights work but when the hazards come on the whole car surges, power locks and windows don't work, can't start the car with the key
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2005
  • Aug 3, 2005
What kind of problems? More information is needed.
J
jvann07
cincinnati
Aug 4, 2005
  • Aug 4, 2005
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 4, 2005
  • Aug 4, 2005
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the datbase, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
If they won't do it, Autozone will sell you the switch for $10-$12. You'll need a tamper proof torx bit to remove the switch. It is either a t25 or t27 size. Check the wiring for heat damage while you have the cover off.
See http://forums.stangnet.com/showthread.php?t=523585 for more information
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
  • dan50
  • Jul 18, 2026
dan50
