Electrical Gremlins
Black Sun 5.0
1,337
L.I., N.Y.
This, I guess is a bit of a continuation of numerous issues I've been having since rebuilding my Mustang. Some parts came from another vehicle, so I guess there may be integrity issues. Today's issue to narrow down (I swear I'll get all of them): I realize that the horn and the cigarette lighter and I believe the cruise control are all tied to the same circuit. I haven't tested the cruise, but the horn and the cigarette lighter are not working. I checked the fuse already, and it's not blown. Funny thing is, though, that when I press the horn button, I hear a quick clicking noise and no sound from the horn. Which guru wants to take a crack at this one?
Remove your right front wheel well and get to your horns by the core support. The clicking noise you are hearing should be the horn relay.
1st, use a dmm and see if your getting 12 volts @ the horn when you press it @ the steering wheel- It is possible that the horns might not work or the ground might be bad.
2nd, if your relay is working but you get no voltage @ the horn , then check the fuses because your not getting power into pin 30 on the relay.
3rd, if that doesn't work your output of the relay- pin 87- has a short in it and not making it to the horn.
4th, why do you need a horn? If your ahead @ the track then you shouldn't have to honk @ anyone.
Good Luck.
I'm not sure if they share the same relay/power source. If you check around some of the electrical threads around here you could find it.
The only way to hunt the gremlins is to start at the end or beginning of the circuit and work your way in. That will get them!!!
