Electrical Problem...please help!!!
  • Thread starter Thread starter md20
  • Start date Start date Jun 6, 2005
md20
17
  • Jun 6, 2005
I was just at a performance driving class in College Station, Texas and went through hell and back getting my stang to run for only one session. I kicked butt, passing a couple of lotuses, a beamer, and some other expensive car. However, after that on the way to dinner, my car dies again.
I replaced the alternator (finally got a 130 amp/$130 amp) twice Saturday, and then had to put in a brand new gel cell battery ($180). It only worked for about 6 hours, now it's dead again.
Any suggestions as to what might be wrong? Do I need to get a new wiring harness and have everything redone? Please help.
stang22
1,318
Washington, D.C.
Jun 6, 2005
  • Jun 6, 2005
Is it not cranking? Is it dying when you are driving it? Need more info...
Tim
04sleeper
2,674
14
89
Dallas, TX
Jun 6, 2005
  • Jun 6, 2005
Did you upgrade the wire to 4 gauge? I would also check the excitor wire to see if it is getting power.
In what condition are your battery cables in?
md20
17
  • Jun 6, 2005
Now it's not doing anything. I was fine late saturday, now I think the battery has been fully drained because it won't even turn over.
md20
17
  • Jun 6, 2005
I haven't changed any of the wiring on the car. I bought it about 2 years ago and it was bone stock.
04sleeper
2,674
14
89
Dallas, TX
Jun 6, 2005
  • Jun 6, 2005
Then how did you hook up a 130 amp alternator? You have to cut off 1 plug to do so.
Maybe this will help.
stang22
1,318
Washington, D.C.
Jun 6, 2005
  • Jun 6, 2005
Check your grounds, sounds like it's a possibilty. Does it not turn over when it is cold also?
Tim
md20
17
  • Jun 6, 2005
Hey 89, I think that's it. I noticed that the two wires on your diagram were both put together at the "4 gauge wire to solenoid." I guess I need to un hook them and find which one is 4 gauge and leave that one on, then re-attach the other wire to the arrow that says "power when car is running"? Is this correct?
How do I know which one is 4 gauge? My mechanic at work did the install, so I guess he got the wiring wrong. It doesn't look like the middle port is able to take a wire. Is that a bolt that screws in?
Thanks for the help, I really appreciate it.
04sleeper
2,674
14
89
Dallas, TX
Jun 6, 2005
  • Jun 6, 2005
Actually the two wires that were both put together are the factory 10 gauge wires. They run to a single 10 gauge wire down a little further in the harness.
It should work with both wires hooked up to the treminal but I recommend that you unhook both wires and run a single 4 gauge wire from there to the starter solenoid.
The small "White/black" wire is your excitor wire and should be hooked up as shown. There is no bolt there, just a spade for a connector. You can use a female speaker connector for the mean time to hook it up but make sure it is getting power when the car is running. Use a test light for this to make sure. If it doesn't get power then the alternator will not charge.
04sleeper
2,674
14
89
Dallas, TX
Jun 6, 2005
#10
  • Jun 6, 2005
  • #10
I bought one of these when I did mine and rewired it.
It's only $20 and works great.
Go here to see.
http://fordfuelinjection.com/index.php?p=67
md20
17
#11
  • Jun 6, 2005
  • #11
I'll try that....thanks again.
04sleeper
2,674
14
89
Dallas, TX
Jun 6, 2005
#12
  • Jun 6, 2005
  • #12
No Problem.
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Electrical no start no crank no power. help please
  • 85blue
  • Sep 23, 2021
2K
Fox 5.0 Mustang Tech Sep 25, 2021
General karthief
Electrical 90’ lx dies while driving or idling randomly please help
  • Black_Mare
  • Dec 22, 2018
4K
Fox 5.0 Mustang Tech Dec 27, 2018
Black_Mare
Car put me down......again. What now?
  • Wayne Waldrep
  • Sep 10, 2019
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2023
Mindseye007
J
Please Help Can Not Figure Out Electrical Problem
  • Jess4tin
  • Mar 20, 2017
2K
1996 - 2004 SN95 Mustang -General/Talk- Mar 21, 2017
HawkX66
