- Aug 19, 2009
- 6
- 0
- 0
I'm having an electrical problem and have no clue what it is. I'm a noob and still learning so please take it easy on me. Here is my problem, well one of them anyway lol.
So, I'll start from the beginning. My '93 LX 302 would start fine and run fine until one day, I would come out of work to leave and it would be dead. I'd need to jump it. Once I jumped it, I was fine. BUT it started to get worse and dying more frequently. So, one day I turned it off, went into work and forgot something so I came back out only a few minutes later. Well, when I got in my car, the radio was on! It was NOT on when I turned it off and there is no key in the ignition mind you. So, I was baffled. I put the key in, jiggled it (because the ignition switch/lock is messed up (bought it like that, haven't had the car that long). So after that it was fine. So I had to be real careful after that but only drove it a few more times until my front end problem started and had to stop driving it. I parked it. I had let the battery die again while it was parked so I just ended up buying a new one. But since it was parked, I just disconnected the new one so it wouldn't drain. Well it been a while and that battery ended up dying.
So since it was just sitting because I couldn't afford to fix the front end problem, I figured I'd just jump it next time I wanted to start to car. So just recently, I thought it's time to bring it back out and try to work on it (its a project). Well, I had to jump the battery of course. So I jumped it, it starts right up (never gives me a problem starting if there's juice) and let it run for a while because it has been sitting. But when I went to depress the clutch to put it in gear to move it, it dies! And will NOT start again unless it is jumped. I mean it dies completely, no light nothing. And it will die everytime. So it is currently not drivable at all.
I did some research and I think I narrowed it down to something electrical (yeah , I know not too narrowed but I'm a noob still). I know it could probably be several things but here are some things to consider:
Previous owner did all of this btw
gauge cluster was messed with (he went for the white faces, don't know exactly what he did though, whether the whole cluster was replace or not)
every gauge is either off or don't work
aftermarket radio was installed BUT I completely uninstalled it to replace it and there is currently NO radio
heater core is bad, antifreeze leaks of course BUT I made sure there was enough in there at the time.
I can tell there used to be additional gauges (one on the dash, a few on the door) but they were removed before I bought the car
he had some kind of neon lights installed because the switch that controlled them remains (its just disconnected)
there is a 'chip' that helps prevent theft that you must use in order to start it. which i have and it seems to work fine i guess
I tell you guys all this because it is all electrical related and may be contributing to the problem. So, what do you guys think?? I would so appreciate any help with this as I would love to get it 'drivable' again at minimal expense. I mean I was gonna start with the front end (horrible clunking, popping like sound; but that's a whole other thing) until this happened. So I'm open to anything I could possibly do myself. Sorry for the long post but I wanted to give as much info as possible to help.
Thanks a lot!
Thanks a lot!
