Perhaps the title is a little dramatic, but I am at my wits end.
I am doing the old 4cyl to 8cyl conversion on an 86 fox body.
Most everything is done I am just tidying everything up and trying to make the last few modifications.
I have had the engine running in the past in this car but every once in a while I would go to start it and it would continue cranking even after it’s started. The solenoid gets stuck and the juice stays flowing to the starter. In this case I have replaced the solenoid. Recently it did this with a brand new solenoid at the first crank.
I had a ****ty battery which was on its way out and so I replaced it with a bigger battery and also mounted it in the trunk. As soon as I tried to crank it over it would barely crank and the brand new solenoid got stuck again. My best guess is that there’s a short somewhere in the endless wires or I have one connected where it shouldn't be. Any guidance or suggestions would be appreciated,
Thanks,
Ray
Thanks,
Ray
... but at least its not an electrical issue, bolts I can deal with.
