• Community Forums
  • Regional Forums and Event Information
Electrical short
  • Thread starter Thread starter dception
  • Start date Start date Jun 11, 2005
D
dception
12
  • Jun 11, 2005
Hey
I have a 90 mustang convertible, and I shorted a wire somewhere. There was smoke coming from the steering column. The ignition key won't crank the starter, although the accessories come on. (Ie. radio, wipers, hazards, horn)The convertible top doesn't work, the directionals don't work, and also the heater blower. Any suggestions as to where to start looking for the short?
Thanks
01SN8K
135
  • Jun 12, 2005
well to find the cause you would need a manual with the wiring harness in it. What did you do to cause the short? most wires in the steering column are bundles so you may have a pinched wire that is causing the short. check all your fuses also. well the shop manual will give an idea as to where to start your wire search. find all ignition wires, and locate any wires to the convertible top if there are any in the steering column. hopefully it is an easy fix such as a ripped wire insulation and a blown fuse. good luck
D
dception
12
  • Jun 12, 2005
Thanks, will give it a try!
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
P
Crank but no start BUT no power to gauges
  • project_88LX
  • Jan 13, 2025
Fox 5.0 Mustang Tech Jan 14, 2025
Mcmahst
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
  • Community Forums
