Emergency flashers
66newbie
84
Did a search and didn't find anything so I will ask. I moved the emergency flasher to get better access under the dash for a few minutes. I noticed something wierd. When I put it back in place it seemed to blow a fuse. I double checked it. I replaced the fuse then when I wiggle the flasher (by loosening the bolt) it causes a fuse to blow. Seems like it grounding out on the dash or something. The flashers themselves work fine.
That's just it, the flasher switch itself doesn't seem to cause the short. If I loosen the bolts that hold down the housing containing the switch and just wiggle THAT, not the actual switch, it blows a fuse.
