emission tab tad sensor
  • Thread starter Thread starter noslow1986
  • Start date Start date Jul 8, 2009
N
noslow1986
274
oswego Il
Jul 8, 2009
  • Jul 8, 2009
do i need these tab and tad sensor i dont have any emission so i dont know if i take them out if it will hurt anything
HISSIN50
34
129
Jul 8, 2009
  • Jul 8, 2009
If you don't have a smog pump, they aren't doing much good.
N
noslow1986
274
oswego Il
Jul 8, 2009
  • Jul 8, 2009
nope got rid of all of it there are lines vacuum and other lines going into the firewall and i cant see where there going so tommorrow i take all the extra junk off
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2009
  • Jul 8, 2009
TAB & TAD solenoid valve eliminators – eliminate codes 81 & 82.
You will still get 44 & 94 codes because the computer looks for a change in the amount of oxygen by checking the O2 sensors when the solenoids are actuated. Actuating the solenoids provides more oxygen in the exhaust, changing the O2 sensor output. No change and you get the 44 & 94 codes.
Don’t do this if you have a catalytic converter H pipe. The catalytic converters must have the air from the smog pump or they will clog up and choke.
See US - Electronic Components Distributor | Newark.com for the resistors to replace the TAB & TAD solenoids
OHMITE|43F82RE|Wirewound Resistor | Newark.com
If the link fails do a search using the part number
82 ohm, 3 watt wirewound resistor, 94 cents each.
Newark P/N 64K8974
Ohmite part # 43F82RE.
Or use the following part number if the first part number isn't available:
OHMITE|23J82RE|Wirewound Resistor - Vitreous | Newark.com
Newark P/N 64K8241
Ohmite part #23J82RE
Pay a visit to your local Radio Shack to get some heat shrink and some crimp on tap terminals. They do not stock the resistors. Or you can use the Ford connector pin kit from AutoZone.
18 gauge crimp on taps Catalog #: 64-3053
Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAB & TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAB & TAD solenoids if emissions testing comes to your area.
Two flat pin connectors.
One 82 ohm, 3 watt resistor.
One piece 3/8" heat sink tubing 2" long.
Two pieces 3/16" heat shrink tubing 1 1/2" long.
Solder the pins onto the resistor leads using electrical solder.
Slide the 3/8" heat shrink tubing over the resistor.
Slide the two pieces of 3/16" heat shrink tubing over the two wires, leaving the flat part of the pins uncovered.
It helps to have the resistor leads straight and not bent as shown in the first picture when you apply heat to the heat shrink tubing. That way, the tubing shrinks more evenly.
Finally, apply heat to shrink all the tubing uniformly.
Bend the leads to fit the spacing on the female TAB & TAD connector sockets.
Push the connector pins of the completed resistor assembly into the empty female TAD or TAD connector sockets on the wiring harness. The resistor assemblies replace the missing solenoids: one resistor assembly per solenoid socket.
Do not crimp on the pins and wrap the mess with electrical tape and say you got the idea from me. If you do, and I hear of it, I will say unkind things about your intelligence and family heritage. Do Quality Work!
This information is for informational purposes only and is intended for use only on off road vehicles. It should not be used on any vehicle operated on public roads.
Operating a vehicle modified in such a manner on public roads is a violation of the EPA codes regarding modification of emission controlled vehicles.
Q
qwomack
  • Mar 2, 2010
Is there any way to get rid of the 44 & 94 codes?
N
Smog system TAD//TAB solonoids wiring malfunction
  • noob need help
  • May 5, 2025
Fox 5.0 Mustang Tech May 30, 2025
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Vacuum reserve capacity question
  • Mcmahst
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 27, 2025
Mcmahst
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
