first i would go with a true roller timming gear and chain set or ford motor sport
that i think is even beter than the true roller, i have a drag raced 531 with over 200 races on it and the chain still doesnt have any slack ,it has the motor sport set, ring guapping would depend on type of rings used,chrome , cast, ceramic, i never use white grease when assembling the rotating assy., it can dry out if left to set . i have started using stp for assembly ,i usualy prime the engine any way and fire it on a stand before instalation ,one of our engine builders told me to use two stroke oil on pistons when assembling for easy ring break in, never liked the victor gaskets, though
its been several years sence i have used them ,fell pro is the way to go , always used plastiguage for bearing clearance ,started using synthetic oil for crankcase 30 w
not a bad deal for a total of 1700 for all i would be happy with that,machine work can eat up most of the cost of a engine build ,mine is polished balanced and blue printed at a total of $6,579.00 in just machine work.
