Engine Engine Block Question
  • Thread starter Thread starter Zbanks1
  • Start date Start date Sep 19, 2012
Z
Zbanks1
17
  • Sep 19, 2012
I recently bought a 5.0 block out of a 97 GT. I have a 89 GT as well. I am going to have the block bored out. I have been told not to go more than 30 or 40 over. We are aiming to have a 450 whp car when we get done. So how much should I bore out the cylinders and not have to worry about them being too thin and maybe cracking under a heavy load.
benmaini
  • Sep 19, 2012
Well that would depend if you are trying to get that kind of power naturally aspirated. If not then I would suggest keeping the boring to a minimum. if so then 30 is a common choice
R
reldla1996
356
22
Dayton, Ohio
Sep 19, 2012
  • Sep 19, 2012
97's did not come with a 5.0. For the "newer" 5.0 blocks, such as your 89, Ford put a factory limit of .030 overbore on the blocks to meet their standards.
benmaini
  • Sep 19, 2012
consider the compression your planning when making your decision.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 19, 2012
  • Sep 19, 2012
450rwhp is probably not going to happen with an N/A hydraulic roller small block setup. You would rev that thing to 7,500 rpm to get those kind of numbers out of it. Even at that rpm, 420-430 is probably best case out of a 4.030 block with a 3.25 stroke (331 ci). RPM kills the late-model 5.0 blocks, so your best bet is to source out a Mexican block or something equivalent.
If you're going power adder, ignore everything above.
ThatBear
30
38
Sep 20, 2012
  • Sep 20, 2012
Are the cylinder walls worn? Ive always been told that boring s motor out doesnt really help performance too much. Just raises compression due to larger pistons. If they are worn have the shop try 20 over and if theyre not cleaned up go 30. Most shops do this anyways. Either way its still a 306.....oh and its a stock block 5.0....that mustang wasnt a 97
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
R
Engine Block Identification
  • Ranger302
  • Feb 22, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
