- Sep 27, 2004
- 30
- 0
- 0
Hey guys, I currently have a 302 engine with most of the basic mods as I have stated before. This is not a question as to what I should do to this engine, instead, it is about a new engine. I want to be able to still drive my mustang and then drop the new engine in when finished so there is no down time, etc.
So, here it goes... basically I have a $4000-$6000 loan (at least $4000 and can get up to $6000) worked out. I am going to use this to build an engine or buy a crate motor, I have not decided.
And thats where you all come in, what are the pros/cons of going each way. Obviously a crate motor is built by someone else so it can take away from the ways I can screw it up. I was also thinking about maybe a short block and adding other stuff onto it (heads,intake,ect). Im not sure.
Any suggestions as to which crate you would suggest or maybe even parts to use if doing a full build up by myself. By the way, I want to have atleast 350hp but it doesnt have to be. Also strokers are not out of the question either. The motor will be mainly street with occasional strip.
I have a t-5, 3.73 in the rear, dual exhaust with x-pipe, flowmasters, and hooker headers. I also have a Edelbrock performer 289 intake and 600cfm carb but those do not necessarily need to be used in my application.
Thanks in advance for any help.
