engine build ??
blkstangman88
646
so i was looking at a 347 eagle kit from jegs p/n 356-B16022LS and wondering if anyone has experence with this. im pulling the stock engine out of my 88gt and going to build it n/a. im going with the afr185 heads and and decent intake. for the cam i was pondering a B cam but if theres better let me know. what do u guys think?
You will have to get your stock block machined to clear the stroker crank throws. But since you are pulling everything out, this might not be a bad thing.
The B cam is what I would call an OK choice. It will work for sure, but there are a lot of other cams to choose from that are OTS that will give you better performance from the increased cubes.
